I don't believe there is currently a way of doing this on FLX, however I may be wrong. I know you can with FROG2 which is running the same software so the function must be in there.
To get the REMDIM function you can setup a UDK you're not using for REMDIM.
To do this choose an empty UDK and hold SETUP + press it. You can then set it to have a function and shifted function, so you can choose REM DIM from the drop down list.
Hope this helps
Ed's correct, this is available on ORB Series and FROG2, but not currently FLX. One way you can get around it is to record palettes of the fixture you want to copy, and then apply that palette to the new fixture - but this is a little bit long winded.
  • 5 months later...
