Hi
Me and my ORBxf needs a step by step instructions for the update using USB-stick
I have version 7.8.2.40 and i'd like to update to 7.9.1
How can i create a bootable USB?
The latest software version is 7.9.2 so it's recommended you upgrade to that, and I think you must be currently running 7.8.2.39?
First thing to do on your computer is plug in the USB stick, and in My Computer find the USB stick, and ensure there's nothing on it. Then right click, and click "Quick Format". Leave all the default settings and run that. The drive is now ready for putting the ZerOS installer on it. To do that download the version 7.9.2 from the website, and extract the files once complete. Then run the ZerOS 7.9.2 application. This will ask what drive you what the installer on, so select your freshly formatted USB stick. Once this installer has finished, unplug the USB stick and plug into the USB port nearest to the network port. Now boot the ORBXF with the USB connected, and the option to Install 7.9.2 will appear. Click this, and it will install. When it says it's complete, power off the console, unplug the USB stick, and next time you boot the ORBXF it will be in the latest version. It is recommended you read the release notes for further information.
http://zero88.com/support/index.php?/Knowledgebase/Article/View/587/
