Sven76 Posted January 9, 2017 Report Posted January 9, 2017 Hi there, I was not yet able to validate on desk actually, but at least on Phantom I realized following issue: It seams that it is not longer posibel to select a stack (I know there are no stacks anymore but playbacks) with "select stack" and then pressing the button below a playback fader. The only way I was able to select a stack is pressing "Select stack" ; <stacknumer> ; enter For busking a live Show, in my eyes this is way to complex, slow and error-prone. Mostly I need this for overwriting stack (-speed) Is there something I missed? Or does someone know a faster way to idividually overwrite Speeds in a busking-way? Thanks in advance and best regards Sven Quote
ziglight Posted January 9, 2017 Report Posted January 9, 2017 hello maybe you should try on your console... in my case and with the Solution Desk the function that you related stills works as it should (and with the latest "public Beta OS" ) on Solution desk the combination is MEMORY button + the Flash button of the desired Playback (but maybe Orb is completely different... I don't know !!!) Quote
Jon Hole Posted January 9, 2017 Report Posted January 9, 2017 Added as ZOS-7494 There is a new option available though - hold VIEW and press the Playback button. Quote Jon Hole linkedin.com/in/jonhole
Sven76 Posted January 11, 2017 Author Report Posted January 11, 2017 HI Jon, thak you for that hint. VIEW + Playback Button is working for me. Best regards Sven Quote
