Primax98 Posted December 3, 2016 Report Posted December 3, 2016 http://adamhall.invaliddomain.de/out/media/downloads/MARKEN/CAMEO/CLLWOOKIE150G/CLLWOOKIE_CAMEO_Bedienungsanleitung_EN_DE_FR_ES_PL_IT.pdf I have created my own fixture for this and was hoping that someone can check what I have done and let me know if this is correct please, my first attempt at this ! :-) Its a Cameo Wookie 600b Laser I have tried to paste a copy of the link in here but it wont let me hence the code insert. File attached. Cheers Paul CamWook600b.ift Quote
Jon Hole Posted December 5, 2016 Report Posted December 5, 2016 Hi Paul, The only thing I'd definitely change is the default of the "Mode" channel, so it's default is on "DMX Control". Other optional things would be: - set Zoom to "half way" (63 for this fixture) - not sure what "manual rolling" is, but I've set it to half way too (63) - set the "special" dropdown of "X Move" and "Y Move" to "Pan" and "Tilt" so if you're using a ZerOS console, you can use the Pan/Tilt Grid Attached is a file with all of these changes CamWook600b.ift Quote Jon Hole linkedin.com/in/jonhole
Primax98 Posted December 6, 2016 Author Report Posted December 6, 2016 Hi Jon, thanks for this ! Know what to look out for next time. Appreciate the help. Paul Quote
