B.D.Eth Posted November 20, 2016 Report Posted November 20, 2016 Hi, I'm pretty new to lighting so need some help! Is there a way to assign a certain group of fixtures dimmer levels to one fader? I want to be able to, for example, have a scene live in run move and bring moving heads intensity down but not par cans. Kind of like a master for a certain set of lights. I would appreciate a fast response as I need it for an upcoming show in a week Quote
Edward Posted November 26, 2016 Report Posted November 26, 2016 Hello, Hope this reply isn't too late! Put the Jester into Program Mode (Press and hold Mode to get to program from Preset). Select the fixtures you would like to control the intensity of. Set them to full intensity, and then press any fader you would like. Now press the store button. You can now press mode again, and you now have access to your submasters. The fader you just programmed should now have it's LED underneath it lit, and will now act as an intensity master for your selected fixtures. Hope this makes sense and I have answered your question! Edward Quote
