Amy Worrall
Fixture request - "Party PAR"
I'm trying to patch this:
https://www.amazon.com/ccbetter-DMX512-Automatic-Sensor-Handle/dp/B016QI7TCG/ref=cm_cr_arp_d_product_top?ie=UTF8
(well, more accurately the 36 LED version). On the box it's just called "Party PAR", without a manufacturer name.
I don't have the manual, but from trial and error it has channel 1 is brightness, 2 is strobe, and 5, 6 and 7 are RGB. I don't know what channels 3 or 4 do.
(Please don't judge me for using a crappy light — mostly I'm using Stairville LED PARs, which still aren't good but are at least a brand that people have heard of.)
Amy
Hi Amy,
See attached. I've set ch 3 and 4 as Beamshape parameters so you can have a play to see what they do.
As I think this is for your Illusion, I've set wheels for each C/B parameter.
Do you know about the Fixture Editor tools? Load this one up and have a look, then you'll be able to create any new ones you need really easily.
http://zero88.com/support/index.php?/de/Knowledgebase/Article/View/49/0/zero-88-fixture-tools---version-26
Good luck!
Kevin
partypar7ch.ift
Great, thanks!
It is indeed for my Illusion. It gets its first outing in a few weeks :)
I've tried the fixture editor, but only for making a floppy disk out of a subset of the main library. (All my other fixtures were found in there already.)
Thanks,
Amy
