I had cause to use MAC250s with my FLX. I patched the fixtures from the profile built into ZerOS7.9 but found there were errors in the Prism attribute details. I've corrected this in the attached replacement profiles. The error in the fixture profile was due to an error in the MAC250 manual - the detailed description for Prism had the error, whereas the DMX map in the back of the manual documented the behaviour seen with the actual MAC250 (latest 1.4 firmware).
Kevin
mac250.ift
