HugoPilot Posted September 26, 2016 Report Posted September 26, 2016 Hello, I made a custom fixture (.ift) file. But when I try to import the file onto my Jester ML 24, the message "Please Wait" occurs and doesn't go away. I have a Kingston 16GB USB, completely empty with the file on it. I run Jester ML 4.1 on it. Why can't I import my fixture file? Kind Regards, Hugo Woesthuis TDC444.ift Quote
keredyelesob Posted September 26, 2016 Report Posted September 26, 2016 I have had a look at your fixture file and it seems ok to me. I also loaded it onto my FLX and that worked to, I will try my solution when i get home. I know it is not a Jester ML but i would have thought if they load onto the other desks then the fixture file is OK. have you tried a small pen drive, I know if i use a larger pen drive on any of my consoles it is a lot slower. I would try with a 1GB pen drive. Quote
Jon Hole Posted October 13, 2016 Report Posted October 13, 2016 I have a Kingston 16GB USB, completely empty with the file on it. I run Jester ML 4.1 on it. I would try with a 1GB pen drive. Yeah, Jester hardware isn't a particular fan of "large" memory sticks, so I'd give it a go with a smaller one if you can. Quote Jon Hole linkedin.com/in/jonhole
