When I add an effect to a fader using the built in Rainbow effect on some RGB LEDs the default behaviour seems to be to fade it in over 3 seconds and then snap out when the fader is back at zero. How do I change this so the fader controls the intensity of the effect?
  • 3 weeks later...
The 3 seconds fade is coming from the fade time of the cue you're triggering when you raise the fader. I would assume "colour" is set to 3 seconds (as this is a colour effect, it will use that fade time).
If you go into the Playback settings (SETUP + the playback flash button) you can select "Fader Controls... Effects" - now as you raise the fader the size and speed of the effect will increase, and when you lower the fader the size and speed of the effect will decrease.
Jon Hole
