luke1307 Posted September 12, 2016 Report Posted September 12, 2016 Hi there, Is there a way I can use the Udks to trigger my par cans into flooding the stage in one colour while blacking out the other fixtures even if there all running a sequence on a playback? Quote
jw-lighting Posted September 13, 2016 Report Posted September 13, 2016 1. Record a playback onto the UDK (Set your PAR cans as you like, press <Record>, press <UDK>-Button) 2. Press <Setup> + <UDK> together to configure the UDK. Select "Solo" instead of "Latch" or "Flash" 3. Enjoy Quote
luke1307 Posted September 13, 2016 Author Report Posted September 13, 2016 Hey, Thanks for this, but I have done that, but the other fixtures stay on. Even with the Udks set at latch and not flash. Have also tried changing the htp and ltp setting Oh sorry I read that wrong, I don't have a solo option on mine, and I can't update the desk as the update been taken down Quote
jw-lighting Posted September 13, 2016 Report Posted September 13, 2016 Oh sorry I read that wrong, I don't have a solo option on mine, and I can't update the desk as the update been taken down Hmmm. Now, I'm not sure at all if there is a Solo option for the UDKs. The playbacks have one. As a workaround you could use a playback instead. Quote
luke1307 Posted September 14, 2016 Author Report Posted September 14, 2016 Ok that's great thank you for your help. Jon is a solo option for the Udks possible to add please Quote
Jon Hole Posted September 14, 2016 Report Posted September 14, 2016 Jon is a solo option for the Udks possible to add please It's on the list :-) Quote Jon Hole linkedin.com/in/jonhole
