Hi
Been setting up my Orb XF to busk some band night type shows.
So on my movers I've been recording colours position and effects on different sub masters
Is there a way to either set the sub master to increase the speed of the effect as you raise the value or to set an effects sped master?
Many thanks
D
Hi Lightmaster,
There are various options, depending on what you want.
One option is if you hold SETUP and press the flash button of the submaster, there's a setting called "Submaster Controls..." - make sure "Effect" is enabled. Now, the effect will get larger and faster as you bring up the fader, and smaller and slower as you bring the fader back down.
