Kevin Coulombeau Posted August 25, 2016 Report Share Posted August 25, 2016 HelloI m sorry for my English writing I 'd need help connecting my console solution wysiwyg r32I respect the use of this manual for connection but without result i use a windows 10 pc (ip address manual 192.168.1.50) the Zero 88 Driver Installation WYSIWYG tool (192.168.1.50) On the screen console ( driver wysiwyg connect, wysiwyg transmitted 192.168.1.250) I use wysiwyg r32 in the window device manager/properties (name :solution adresse : 192.168.1.250) I click CONNECT and an error message to say the console shouldn't connect I think that there is a very basic mistake unfortunately I'm stuck and can not move forward in the writing of my shows I have a friend who owns a grandMA2 . he had to change the IP address (in the window device manager / properties ) by grandMa1 weird but may be the same problem , I tried several names, but no result can help methank you in advance Quote Kevin - Orch Galaxie Link to comment Share on other sites More sharing options...
Jon Hole Posted September 1, 2016 Report Share Posted September 1, 2016 Hi Kevin, We wrote our driver several years ago when WYSIWYG didn’t support Art-Net directly. However, now (and for several years) it has supported Art-Net, so that’s by far the easiest option – ignore the WYSIWYG driver, and ignore the settings in the “visualisation” part of SETUP, instead just concentrate on the Art-Net settings, as if it was any other Art-Net device. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Kevin Coulombeau Posted September 11, 2016 Author Report Share Posted September 11, 2016 Hi John Thank you for you answer I tried Art net , i have some signal in the Dmx patch of Wysiwyg but i can t connect and have the visual of the consol in the "live" part. In the device manager should we do something special ? I also tried Captur ( demo) but it does not work. Thank you Quote Kevin - Orch Galaxie Link to comment Share on other sites More sharing options...
ziglight Posted September 11, 2016 Report Share Posted September 11, 2016 I also tried Captur ( demo) but it does not work. Hello Capture workes fine for me (Solution Desk) so there might be some errors in your network-setup ! do you connect by a Wi-Fi router ? or by "wired" ? Quote Link to comment Share on other sites More sharing options...
Kevin Coulombeau Posted September 12, 2016 Author Report Share Posted September 12, 2016 HelloCapture workes fine for me (Solution Desk) so there might be some errors in your network-setup ! do you connect by a Wi-Fi router ? or by "wired" ? Hello I tried with the fantom zéro (ip adress 127.0.0.1) I Also tried the solution controler with a wifi router 192.168.1. .. I also tried live connection (by wired) Can you make a demo Video when you connect the controler to capture I m a beginner to network setting Quote Kevin - Orch Galaxie Link to comment Share on other sites More sharing options...
ziglight Posted September 13, 2016 Report Share Posted September 13, 2016 are you shure that you really own a valid licence for your Cast-WYSIWYG Software ????? Quote Link to comment Share on other sites More sharing options...
Kevin Coulombeau Posted September 13, 2016 Author Report Share Posted September 13, 2016 The licence wysiwyg is valid bécause i use with GrandMa 2 controler Just a small différence when you would connect in the soft (device manager to wyg in the place "adress" i write " grandMa1" instead of ip adress or artnet adress John or ziglight what do you think ? Quote Kevin - Orch Galaxie Link to comment Share on other sites More sharing options...
Jon Hole Posted September 13, 2016 Report Share Posted September 13, 2016 Hi, If you are "a beginner to network setting" then we should probably start at the beggining... I think we need a little more information on your setup. - What IP addresses are everything on the network. - Are there any switches / hubs / routers? - Are you using Straight or Crossover cables (each individual cable you're using) - How is everything plugged up If you give us all this information, we can have a look at what might be wrong. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Kevin Coulombeau Posted September 22, 2016 Author Report Share Posted September 22, 2016 Hello So after some hours of research I found the solution to connect the console to wyg with art net in device manager i dont use console solution but the Art Net Artistic console , do not enter the address 10.x.x.x in any case, from the beginning I used the correct settings network the wyg on the console and the soft ZERO88 wyg is useless , it's a shame it might be wise to zero 88 to update these utilities that it works, because the manual says use thank you john and zygliht remains for me to work on my shows Quote Kevin - Orch Galaxie Link to comment Share on other sites More sharing options...
