nerdsteve Posted August 23, 2016 Report Posted August 23, 2016 Hey, Could some one make me a fixture profile for the Chauvet DJ 4BAR? This is a first generation, so it only has a 15 ch mode and not a 3ch mode (which I would love to have). Which is leading to some frustration I'm having with the fixture editor and how I'm trying to run them. Below is the Manual. https://www.chauvetdj.com/wp-content/uploads/2015/12/4BAR_UM_Rev6_WO-1.pdf Thanks, Steve Lunney Quote
KWR88 Posted August 24, 2016 Report Posted August 24, 2016 Hi Steve, Please see the attached fixture. it contains the 3, and 15 channels versions. You have not mentioned which desk this for but if it for one of the Zero OS desk then you may find it easier to control but by actually splitting this into four separate fixtures with consecutive DMX addresses. To aid in this there is also a set of four profiles one called master, then pod 2, 3 and 4. You can then set up a group that would allow select the whole fixture quickly. 4 bar.ift Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
nerdsteve Posted August 24, 2016 Author Report Posted August 24, 2016 Keith, Sorry, I'm using the Solution light control console. However I didn't think of breaking them off into pods. Thank you for the aid into this. -Steve Lunney Quote
