milkyman90 Posted March 26, 2004 Report Posted March 26, 2004 Hi Need a speedy reply if poss. I've hired a Fat Frog and are controlling some Mac250s with it. How do you focus these fixtures with the desk? I had a play today with the four buttons (brightness, colour etc) but cannot see a focus setting. It's probably really obvious, but I don't really have time to explore!! Please help! Jamie 8O Quote
sam.henderson Posted March 26, 2004 Report Posted March 26, 2004 Jaime, Select the Ftixtures you want, then press Beam Shape in the Fixture Control area then press Wheel Group next to the first finger wheel until you see focus as an option on the Fixtures LCD, Hope this helps, Sam Quote Sam for a interactive training suport program on how to use your fat frog effectivly why not look at my frog training program-
milkyman90 Posted March 26, 2004 Author Report Posted March 26, 2004 Cheers for that, I remember seeing that button now! I assume you can access the prism effects settings that way too? Jamie Quote
sam.henderson Posted March 27, 2004 Report Posted March 27, 2004 assume you can access the prism effects settings that way too? Yes indeed you can, Just for information; BRIGHTNES Wheel Group One- Dimmer COLOUR Wheel Group One- Colour BEAMSHAPE Wheel Group One- GoboRot--Sh/Res--GoboSe1 Wheel Group Two- FX Speed--Focus--Prism POSITION Wheel Group One- Pan--Tilt--MovSpeed Wheel Group Two- Effects--Size X--Size Y Wheel Group Three- Offset (%)--Rotn--Speed. You can always tell if there is more than one wheel group because the wheel group buttons LED will be illuminated. Hope this helps, Sam Quote Sam for a interactive training suport program on how to use your fat frog effectivly why not look at my frog training program-
K-Nine Posted March 29, 2004 Report Posted March 29, 2004 Sam has summarised it quite nicely If there are more parameters for a particular attribute than will fit into one wheel group, the LED in the Wheel Group button will be lit. Pressing the Wheel Group Button will cycle through the wheel groups and the corresponding fixture parameters will be displayed on the Wheel LCD. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
