paulcobb Posted June 27, 2016 Report Posted June 27, 2016 Hi, I am sucessfully using ADJ Mega Tripar Profile - 7 channel on Frog desk. I have aquired some ADJ Mega Tripar Profile Plus. This has a different setup apparently - up to 10 channel- but does not match the previous model. Cannot see a fixture profile for this model on the website. Can I use? Thanks, Paul Quote
kgallen Posted June 27, 2016 Report Posted June 27, 2016 There's no reason why you can't use this new light, but you will need to build a new fixture profile for it. Do you know how to do that with the Fixture Tools? http://zero88.com/forum/topic/6230-fixture-tools/ You could load the file for the light you currently have into the Editor and use it as a basis for the new one. Give it a go, it's quite straightforward. You can always come back on this thread and ask for more help. Posting a link to the manual would also be handy, and indicating if there is a specific mode you need. Good luck. Kevin Quote
