charliez Posted June 24, 2016 Report Posted June 24, 2016 i tried to patch dimmer 1 thru 5 to a DMX channel like 20, how to do that? i went through forum and user manual, could not get the right answer. i only saw duplication which is patch one fixture into multi DMX address? if someone can point out where i should look at, thanks a lot. Quote
ziglight Posted June 24, 2016 Report Posted June 24, 2016 hello go to SETUP- Edit Fixtures - Patch select channel 20 (for exemple Shift+Flash-Button) change DMX address from 20 to 1 (if initial patch was 1:1...) then click add to add other DMX addresses (2 to 5 in your example) -> Duplicate1, Duplicate2, Duplicate3..... etc etc.... Quote
charliez Posted June 24, 2016 Author Report Posted June 24, 2016 Thanks ziglight, you are so helpful Quote
