jona6tc Posted June 20, 2016 Report Share Posted June 20, 2016 Hi I have a Jester ML24. I am new to lighting (well DMX) and am slowly getting my head around this desk! I have worked out how to assign a moving light fixture to one of the buttons (top right) but can't seem to be able to remove them or even overwrite them with a different lamp. When I go back to assign it won't offer me that 'channel' anymore as there is already something assigned. The only way I have found to remove them so far is to reset the desk to factory settings which is clearly a tad extreme! I'm sure this is obvious and I will groan when I know how! Many thanks Jonathan Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted July 28, 2016 Report Share Posted July 28, 2016 Hi Jonathan, To remove a fixture (from within the <Assign FIxtures> menu), highlight it and then press and hold the CLEAR button. To unaddress something (so you can use that DMX address somewhere else), go into the <DMX Patch> menu, select the channel and then just tap the clear button. Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
