Sign in to follow this
minimac
laser control
Add an optional DMX controller for remote control of tons of special Stinger laser effects.
think you have to buy a special controller for the stinger where there are shows preprogrammed.
2) If you have the right personality files I would control normal lights, but for lasers I'm not sure.
3) I hope for the guys @ zero88 that there are a lot in the world
The fatfrog can control anything with DMX if you write a fixture personality for it. However as Yves suggests, for things like lasers you might find it easier to use a dedicated controller, which will have pre-programmed effects specific to the device.
Yes we do know how many fatfrog desks there are in the world :D
If your laser device has a DMX addressing system, you should be able to work with it. We have an elation power spot, which has a basic type of laser, and I can do designs by moving the head with mspeed. If DMX is there, use the fixture editor tool and create you fixture library for the laser, load and go.
