yes you have to change the personality files.
open the Fixture Type Editor
-> open existing fixture type file
-> select the wanted fixture file and open it
-> select parameters
-> double click on the attribute you want to change
-> adjust the default value in the requested value
Make sure that you save you fixture file when you are done editing. I've done the same think to all my fixtures. Default Brightness is 0, and shutter is 255. this allows me to program quickly while controlling the dimmer for light transitions, unless you are strobing.
Hans Devouassoux
Capital Community Church
