machmo101 Posted June 4, 2016 Report Posted June 4, 2016 Hi all,Was wondering if anybody could help me?I am trying to use timecode via QLab in order to activate a cue stack.How would i go about doing this as my attempts so far haven't worked!Cheers -Matthew Quote
Jon Hole Posted June 7, 2016 Report Posted June 7, 2016 Hi Matthew, Have you enabled MIDI Show Control (MSC)? You do this in SETUP > Desk Setup > Inputs > MIDI Show Control MSC works on Cue Stack 1, you can then use this Cue Stack to trigger other cue stacks. The last thing to ask is what device/cable are you using to output MIDI from the Mac? We’ve seen lots of problems with customers using cheaper cables, like these: http://www.arvydas.co.uk/2013/07/cheap-usb-midi-cable-some-self-assembly-may-be-required/ Quote Jon Hole linkedin.com/in/jonhole
Paul Finch Posted May 26, 2017 Report Posted May 26, 2017 Hi Jon with the new version now using play backs. what play back is used for msc please? Hi Matthew, Have you enabled MIDI Show Control (MSC)? You do this in SETUP > Desk Setup > Inputs > MIDI Show Control MSC works on Cue Stack 1, you can then use this Cue Stack to trigger other cue stacks. The last thing to ask is what device/cable are you using to output MIDI from the Mac? We’ve seen lots of problems with customers using cheaper cables, like these: http://www.arvydas.co.uk/2013/07/cheap-usb-midi-cable-some-self-assembly-may-be-required/ Quote
Edward Posted May 26, 2017 Report Posted May 26, 2017 Hi Paul,I'm pretty sure Playback 1 is still used for MSC in ZerOS 7.9.2.  EDIT: After the update it is now the Master Playback 0.Edward Quote
Paul Finch Posted May 26, 2017 Report Posted May 26, 2017 Thank you Edward. Have u tried this with scs by any chance. Quote
Edward Posted May 26, 2017 Report Posted May 26, 2017 No I haven't, however using a decent MIDI interface box such as a MOTU brand will work using MSC. Edward Quote
