Fireball40k Posted May 30, 2016 Report Share Posted May 30, 2016 Anyone experienced this? We have a Solution XL with the latest firmware. During the protracted programming sessions for big shows, we find that certain preset faders stop working. For simplicity, think of preset faders 1 to 5. Their collective mix is recorded down onto Submaster A and most of the programming of states is done using the submaster. At some point later I need to use some of the presets individually, however, presets 1 and 2 have stopped having any effect. There is no longer any change in the Outputs window for those channels when the faders are moved. Meanwhile, Submaster A is still working fine and having the desired effect on all five of those channels, including the ones that are controlled by the two preset faders that have stopped responding. In the patch screen, the two affected preset faders are still correctly assigned to the correct channels. The problem does not go away when the desk is switched off and then on again. The only remedy is to do a complete reset of the desk and load the program back in - then the preset faders begin working correctly again. This has happened while programming two separate shows in the last two months and affected different preset faders. The first time it happened, it seemed like a different preset would go out of action each day. I didn't have time to investigate on that occasion, so I just had to re-patch the required channels to different preset faders. This time I did have time to look further into it. But I'd really like this to stop happening any more. I can't pin down at what point the preset faders stopped working, but they were fine at the beginning and they were fine again after a full reset. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 31, 2016 Report Share Posted May 31, 2016 We've had people saying similar before, and it's been related to the "Preset Control" button (it being pressed accidently etc), and the console storing presets and then the A/B faders meaning that certain presets don't work. Have you checked this? Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Fireball40k Posted May 31, 2016 Author Report Share Posted May 31, 2016 Hi Jon, no I haven't but I will keep an eye on this in the future. To my mind that doesn't explain why most preset faders in the same bank will operate, but a few stop working. Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted June 3, 2016 Report Share Posted June 3, 2016 I had exactly the same behavior Fireball40K describes and i used to end up doing a software reset to fix the issue. Keith from Zero 88 came out to visit my site for a completely different reason but while he was there a showed him the problem and he explained the exact thing Jon has mentioned above and this fixed the problems i was getting. although i had no idea i had changed the preset control (I had no reason to) this was the cause of me problem. Quote Link to comment Share on other sites More sharing options...
