keredyelesob Posted May 13, 2016 Report Share Posted May 13, 2016 Hi Not sure if this is a bug or just intentional, but; say you have a chase recorded in cue stack 1 and then your show in cue stack 0, you have some cues in CS0 that trigger and release your chase in CS1. If i then delete my chase in CS1 all of the references for the triggers and releases are left behind, should this not delete all references to CS1? I can see advantages and disadvantage of leaving references, for instance; an advantage would be if you where deleting the chase to replace with a new one, you may want the triggers to remain in place, however a disadvantage would be if you are deleting the chase in CS1 to replace with a manually operated scene, in this case you would want all triggers to CS1 to be deleted with the stack to avaid accidentally running the scene In a similar scenario are the macros, however this works on the principle if you delete the macro all reference to that macro are deleted with it. Again i see the same advantages and disadvantage with macros and i do with cue stacks. Anyhow like i say not sure if its a bug or not, just thought i would ask. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 16, 2016 Report Share Posted May 16, 2016 Hiya, Not a bug, but definitely something we could improve in the future! I've added this as a comment to ZOS-6105 which relates to integrating triggered Playbacks with the Playback which triggered them. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
