Dear Sir,
Will you please help and guide, how I programme the scanner on submaster so I can use them with PAR cans on separate dimmers.
Pl. inform step by step.
Dinesh
By default, the desk is set up to work in Full Mode, where everything is recorded when you hit the red button. If you are using fixtures and submasters, you'll soon find this isn't very flexible. You'll need to go into Super User, and change the programming mode to Partial Mode. This will allow you to record submasters which for example have only your Parcans in, without the scanners.
Have a look in the manual, or search this forum for "Partial Mode" for further information.
I hope I understood your question correctly.
Paul.
