GLX Posted July 30, 2002 Report Share Posted July 30, 2002 Is there any chance of getting a fade in/out time on the subs with out recording it in the memory stack and then having to transfer it to a sub. Because its a pain in the duck having to do it that way. :?: :?: :!: Quote Link to comment Share on other sites More sharing options...
Richard Cooper Posted August 4, 2002 Report Share Posted August 4, 2002 I have just used a Fat Frog for the first time in anger, in a venue that it will see very little use but is a step up from the truly terrible Strand Action 48. I was going to ask exactly the same question! At least I now know how to achieve this, all be it via an indirect route. I was convinced there should be a way as there is a column for this in the subs screen. It would be a very useful feature for the types of show I do. Quote Link to comment Share on other sites More sharing options...
K-Nine Posted December 10, 2002 Report Share Posted December 10, 2002 Is there any chance of getting a fade in/out time on the subs with out recording it in the memory stack and then having to transfer it to a sub.Because its a pain in the duck having to do it that way. :?: :?: :!: Frog Reference No 5266 - to be reviewed. At present, channel data loaded directly onto a submaster can only be output manually. Memory data transferred onto a submaster can be output manually or timed (using the fade up/down times programmed into the memory). This is one area where we are looking to improve the functionality to make it more flexible. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
