JamesBH Posted March 2, 2016 Report Posted March 2, 2016 Hello. To put it simply, is there a way to programme fixture movements into submaster 1 and then use submasters 2 & 3 to flash between the odd/even light output without restarting the movement programme? Is this done with tracking? Quote
keredyelesob Posted March 2, 2016 Report Posted March 2, 2016 Hi if you are not using an effect to flash the intencity it should be posible using tracking with smart tag off. Record your effect movement. Then clear programmer and record only the intencity making sure the only thing tagged is intencity. (In the parameter lcd you will see what is taged by inverted text) hope this helps you. Let me know if not. Quote
Jon Hole Posted March 4, 2016 Report Posted March 4, 2016 Yes - I usually have a bank of submasters purely for intensity, and then store position/colour/effects on all the other submasters without any intensity, so I can do exactly this. Quote Jon Hole linkedin.com/in/jonhole
JamesBH Posted March 4, 2016 Author Report Posted March 4, 2016 Thank you. I will look into this next time I'm setup! Quote
JamesBH Posted April 14, 2016 Author Report Posted April 14, 2016 Thanks for your help, I cracked it and it's working a treat! Quote
