OllieNom Posted February 27, 2016 Report Posted February 27, 2016 Hi, I've noticed that the FLX can display small pictures on various palettes, such as the colour that the palette represents in Colour or a picture of the Gobo represented in Beamshape. The profile for the Martin MH1 Profile Plus doesn't have any pictures of the gobos, but I have the pictures and have been trying to add them to a new profile using the fixture editor for Windows. Does anyone know how you do this or has anyone done it themselves? Thanks, Ollie Quote
kgallen Posted February 27, 2016 Report Posted February 27, 2016 Hi Ollie, In the fixture editor, in the beamshape attribute, click the Details tab, then you can select the DMX range for the gobo and load the image against that range. Hope that helps. Kevin Quote
OllieNom Posted February 27, 2016 Author Report Posted February 27, 2016 Hi Kevin, Thanks for your reply. I've tried this a couple of times, but the images never save. I also tried loading all the images into the Manager part of the Details tab, and they're all there, but I can't assign an image to a DMX range. I'm not sure which button I should be pressing - I've tried Load, paste and select but no joy with any of them. Thanks, Ollie Quote
kgallen Posted February 27, 2016 Report Posted February 27, 2016 So I haven't tried this through to loading the fixture into the FLX, but I can certainly attach an image to a DMX range. So - you have a beamshape attribute for say gobo. Details tab. Name=gobo1, End Value=23, Mid=15 Load - pick an image for the gobo Insert Name=gobo2, End Value=50, Mid=40 Load - gobo2 image Insert etc until you've gone all the way to End Value=255 Load/Insert OK This saves OK for me and attaches the gobo images to the ranges as above. Does this not work for you? Quote
OllieNom Posted February 27, 2016 Author Report Posted February 27, 2016 Hi Kevin, When I try these steps, I get a dialogue box which reads "A detail already exists with the given end value". I've attached an image which will hopefully help. Thanks, Ollie Quote
JB97 Posted February 28, 2016 Report Posted February 28, 2016 Hi Ollie, For Gobo 3 to have a start value of 24 my guess is something else is before it, ending at 23. Select the items before it in the list, add the images and click replace, hopefully that will help. Cheers, James Quote
mikeb Posted February 29, 2016 Report Posted February 29, 2016 Hi I may be mis-reading the thread but it sounds like you have already defined Gobo 1, Gobo 2, etc so therefore each one already exists when you select "Insert". Try selecting each gobo from the table itself, change the image then select "Replace". When finished, save the file and import as normal. Hope that helps Mike Quote
OllieNom Posted February 29, 2016 Author Report Posted February 29, 2016 Hi Guys, Thanks for your replies. As it turned out, mikeb and James were both correct about using 'replace', so thank you both. It appears that the profile already had blank images stored for each DMX range, which is why 'insert' would throw an error. Thank you all for your help, Ollie Quote
OllieNom Posted February 29, 2016 Author Report Posted February 29, 2016 Hi Again, So the pictures have now saved into the profile, but I loaded it into the FLX, unpatched and re-patched the new fixtures, but the pictures don't show up on the display, just the same blank blue boxes. Ollie Quote
keredyelesob Posted March 1, 2016 Report Posted March 1, 2016 Not sure if this will help but i asume you have tried updating a standard fixture did you change the name slightly. It is just a thought but the desk may still be picking up the standard fixture over your new custome one.if you change the name you can be sure you are using your new fixture. When i have made fixture profiles with gobo images they have worked but i always rename them if modifying a profile. I cant remember if the images only show in the pallets when the fixture is selected but i assume you have already done this 😊 Quote
OllieNom Posted March 3, 2016 Author Report Posted March 3, 2016 Hi keredyelesob, Actually I haven't tried this yet; I probably should have done that. I'll give that a go and hopefully it'll work. Thanks, Ollie Quote
keredyelesob Posted March 3, 2016 Report Posted March 3, 2016 Fingers crossed. If it still refuses to work upload your file and i will try it here. 😊 Quote
Jon Hole Posted March 4, 2016 Report Posted March 4, 2016 On 3/1/2016 at 11:25 AM, keredyelesob said: I cant remember if the images only show in the pallets when the fixture is selected but i assume you have already done this Yes, images are only shown when the fixtures are selected. Also, you'll need to choose "Automatically create palettes" again after patching the new profile Quote Jon Hole linkedin.com/in/jonhole
OllieNom Posted March 4, 2016 Author Report Posted March 4, 2016 Hi Again, It works! Thank you both for your suggestions. Jon - I see what you mean about automatically creating new palettes again, that works too. The pictures showed up straight away on the view you get when you press the button in the middle of the scroll wheel that currently has control of that gobo wheel. Thanks again, Ollie Quote
