Custom Position Effect Palettes
Hi,
I've been trying to get a pair of moving profiles to swing up and down an aisle, but they are not centrally located, so a simple vertical line doesn't do the job. I was wondering if anyone knows how to, I suppose, 'draw' a custom path using something like the pan/tilt grid, then save this as an effect palette for later use.
Any help is much appreciated,
Ollie
Hi Jon,
Thanks for your reply. That sounds like it will work well, I just wondered if there was a way to resize or move a multiple vertex shape on the pan/tilt grid, then record this as an effect palette as this may come in handy in the future.
Thanks,
Ollie
