labby Posted February 7, 2016 Report Share Posted February 7, 2016 Hi all. i have a leapfrog 96 with the latest software installed and have recently tried to use universe 2 to patch some new effects lights. im an amateur so please be kind, can you run two universes at the same time? universe 2 has a cable running to an extra dmx splitter but no matter what i try i cant get any lights to work on it. both universes are enabled in the setup menu and i have green lights on all of the splitter output channels. any help would be appreciated. i tried using an rgb par to test it but still nothing Quote Link to comment Share on other sites More sharing options...
kgallen Posted February 7, 2016 Report Share Posted February 7, 2016 From the manual p42 so long as you selected universe 2 when you patched the fixtures then you should be good. A universe is just another independent set of 512 DMX channels so it's just a patching action on the desk, your LED lights will just have an address in the 1-512 range on their setting. In the Edit Fixtures screen under the DMX column you should see entries like 2/xxx where xxx is your fixture DMX address, manual p45. Can you plug your LED PAR straight into the universe 2 socket on the desk just to get it going? Kevin Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 9, 2016 Report Share Posted February 9, 2016 If you email us your showfile, we can have a look at it for you :-) Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
