Move in Dark problems when jumping cues
  On 2/9/2016 at 9:11 AM, Jon Hole said:
Hi Rob,
Thanks for taking the time to post here, glad you're getting on with the basics "with ease"!
I've added these two requests as new software issues and below I've included our reference for each of these:
ZOS-6982
ZOS-6983
All the best,
Jon
Expand
Hi Jon,
I don't suppose you have a rough date for these making it into a release do you?
Many thanks
Rob
  On 2/6/2017 at 9:01 AM, Jon Hole said:
As I said before:
Last week we released ZerOS 7.9.2 which was the second of these two updates, so no - these two haven't been implemented yet.
Expand
Hi Jon,
Do you know if these are going to be included in a release in the near future?
Thanks
Rob
  • 10 months later...
Hi Rob,
  On 12/17/2018 at 10:08 PM, robhurt said:
Hi Jon,
Are either of these scheduled for the next release?
Thanks
Rob
Expand
These are not scheduled for the next release. For your reference, these issues have been reviewed, and are now logged on our system as:
- ZOS-2466: Move on Dark should follow jumps in the Cue Stack
- ZOS-6983: Individual cue times for Move on Dark
I have added another request on these issues to prioritise them, however they won't be ready for ZerOS 7.9.5.
All the best,
  • 1 year later...
  On 12/24/2018 at 11:07 AM, Edward- Z88 said:
Hi Rob,
All the best,
Expand
Hi Edward,
Any idea what release these updates will make?
Thanks
Rob
Hi Rob,
  On 2/8/2020 at 6:12 PM, robhurt said:
Hi Edward,
Thanks
Rob
Expand
I’m not sure off the top of my head, will have to check when I’m next in the office. Unfortunately we haven’t had many requests for these, so other enhancements have taken priority.
The best way of achieving this behaviour currently, is to manually program colour, beam and position information in dark, to manually prep them. Therefore if you need a fixture to have timings different to the Move On Dark timing of the playback, record a cue with manual colour, beam and position information in with the fixture dark. To do this you will need to disable SmartTag in the Record Options window, to allow you to store a fixture with 0% intensity. You can then define your own custom fade times for the cue. You can also do this for the cue with the “Next” command in it. In this cue, prep your fixtures manually for the cue you’re jumping to - again with SmartTag disabled to store the colour, beam and position values with the fixture at 0%.
