Vincent Posted January 24, 2016 Report Share Posted January 24, 2016 Hello, I have several submasters recorded; 1 true 10 and 18 true 24 and 39 for instance. If i delete 10 true 18 no problem, but if i try to delete 1 true 39 i get the fold that 19 don,t exist. If i try to delete 1 true 10 and or + 18 true 24 and 19 the syntax line become red. To me this this should be able to work like this ???? What is wrong here??? Records Vincent Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 2, 2016 Report Share Posted February 2, 2016 Hi Vincent, I've just tried this, and it works fine. Deleting submasters using "thru", where not all submasters exist within the range, works fine. Please could you send me your showfile, and exact instructions on how to recreate the problem, and I'll give it a go. Thanks Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Vincent Posted February 18, 2016 Author Report Share Posted February 18, 2016 Hi Jon, Sorry for the delay. I have tried again and using true works fine now. But delete sub 18 + 19 don't work syncs become red, same with delete sub 18 and 19 syncs become red Can you check? Regards Vincent Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 19, 2016 Report Share Posted February 19, 2016 Hi Vincent, Ah yes, I see. However, this does seem to work for Playbacks, so this will sort itself out in the next release because of this thread. Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
