Vincent Posted January 24, 2016 Report Share Posted January 24, 2016 Hello, If have a Orb with Latest software. I put the dish fader mode into channel mode. open channel 1 true 10, press record sub 10. Now sub 10 is recorded but no Intensity of channel 1 true 10 is recorded. I have tried all different options but no result except snapshot but then the risk that al moving head go to there home position if i open this submaster. I hope i should be able to record just the intensity of channel 1 true 10 ??? Right ?? Records Vincent Quote Link to comment Share on other sites More sharing options...
Vincent Posted February 1, 2016 Author Report Share Posted February 1, 2016 Any Response Please ?????? Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted February 2, 2016 Report Share Posted February 2, 2016 Once you record your sub do you clear the programmer by pressing clear twice? Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 2, 2016 Report Share Posted February 2, 2016 Hi Vincent, I think it's probably getting confusing because you're using the faders as both channel faders and submasters. It's not a problem, we just need to make sure you're doing the right process: Just to confirm, are you doing exactly the following: 1) Press "Fader Function", choose "Channels", choose "1-60" 2) Push up the first 10 faders 3) Press "Record Sub 1 Enter" 4) Pull down the first 10 faders 5) Press "CLEAR" twice 6) Press "Fader Function", choose "Submasters" 7) Push up the first fader - you should see Channels 1 - 10 come on to full Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
