Vincent Posted January 14, 2016 Report Posted January 14, 2016 I just recently run on the latest software,and i notice that i still can not update a group. I can record one give it a name and place it on a udk button. If for some reason i need to add channels i can not do this by selecting the channel and call update group (nr) enter. I only can record it and merge. The problem is worse if i need to take out a channel from the group this don't work either with update or record and merge, at least it don't work the way i suspect it should work. Of course if i record and replace it it works but then i lose the name and place in the Udk position, this means double work Is here a easy way fore????? Regards Vincent Quote
Jon Hole Posted January 19, 2016 Report Posted January 19, 2016 Hi Vincent, I've added a comment into ZOS-5598 and this has been scheduled for ZerOS 7.9 Quote Jon Hole linkedin.com/in/jonhole
