RCRLIGHTING Posted January 14, 2016 Report Posted January 14, 2016 Hello and Good Morning from Canada I received 2 used YISCOR CREE 12LED RGBW LED Moving Heads. I was not able to find a similar match to that fixture with the new version 30 of the fixture profiles I downloaded the other day. I tried to create one based on the DMX Values chart provided on line but does not seem to work when I load it into my Fat Frog console. Below are the DMX values listed.... Channel DMX Value Function --------- ------------ --------- 1 000-255 X 0-540° 2 000-255 Y 0-180° 3 000-255 X Fine 0-1.8° 4 000-255 Y Fine 0-1.8° 5 000-255 Dimmer (0-100%) 6 000-255 Strobe (0-100%) 7 000-255 Red (0-100%) 8 000-255 Green (0-100%) 9 000-255 Blue (0-100%) 10 000-255 White (0-100%) 11 000-255 Mixed Colour Change -------------------------------------------------------------------- 12 000-011 No Effect 011-120 Jump Change 121-180 Gradual Change 181-244 Mixed Colour Effect 245-255 Sound Active -------------------------------------------------------------------- 13 000-255 Adjust CH12 effect speed fast to slow 14 000-255 Pan/Tilt Speed adjust fast to slow 15 245-255 Reset More info and fixture can be seen at the following address: http://www.ebay.com/itm/YISCOR-CREE-12LED-RGBW-LED-Moving-Head-Spot-Beam-Stage-Party-Light-DMX-Lighting-/141436177572 Any help creating this profile would be awesome. Thank You in advance for your .time. Rejean Frenette Toronto, Canada Quote
kgallen Posted January 16, 2016 Report Posted January 16, 2016 Hi Rejean, Can you attach your fixture file here so we can take a look? In what way doesn't it work? Kevin Quote
kgallen Posted January 16, 2016 Report Posted January 16, 2016 Hi, Give this one a go. Load this and your own into the Fixture Editor to see what is different. Note: On FatFrog you won't get the channel details for ch12 on the displays. Regards, Kevin Yiscor_12LED_RGBW_Mover.ift Quote
RCRLIGHTING Posted January 17, 2016 Author Report Posted January 17, 2016 Thanks a Million Kevin. As for CH 12...not a big deal. I'll let you know. Thanks again. Rejean. Quote
RCRLIGHTING Posted January 17, 2016 Author Report Posted January 17, 2016 Kevin...You ROCK !!!!!!!!!! Worked like magic.......here is my profile....big difference. Thank You So Much. You saved my bacon !!!!!!!!!! Rejean RCR_Lighting_Jan_2016.ift Quote
kgallen Posted January 17, 2016 Report Posted January 17, 2016 Hi Rejean, The one main thing you didn't do was allocate wheels for each parameter. Under the "3 Wheel Group" tab, you need to allocate each parameter to a wheel. So e.g for Colour, right click and "Add Wheel Group", then allocate each of your colour parameters to a wheel. For this fixture you need more than one colour group for example, as there are 5 colour parameters over 3 wheels. On the desk, multiple presses of Colour give successive pages of colour parameters. Same for beamshape. Also you separated the fine/coarse pan and tilt to two separate channels. Might be preferable to you. In my fixture, I made pan one 16 bit channel. Same for tilt. You'll have to see how you go with these. Other than that, other than setting the defaults (I'm used to how Zero88 usually want them), you're about there. Good luck! Kevin Quote
