I have tried and failed using the fixture builder.
Does anyone have fixture profiles for Showtec Fixtures:
iW-1915 (14ch) , iS-200(18ch) , Spectral M3000 (tour) , Spectral M1000 (tour) ?
If not, who can I contact to help create? Thanks,
Gregor
Do you need all the modes for each light? Or can I only make one mode per Lights?
I'm sorry they aren't done yet, i haven't had time, I'll get them done tomorrow XD
James
James
Hi James,
There is quite a bit of work in these, but you really ought to build the full feature fixture as a minimum. Generally the other modes are then a stripped down version.
Good luck, Kevin
James
James, sorry I missed this reply. Up to yourself, I'm using iW-1918s on 14ch iS-200 on 18ch and the others on tour mode hopefully
Thanks, Gregor
