kgallen Posted December 15, 2015 Report Posted December 15, 2015 Playing with 7.8.5. Thought it better to start a new topic now. The other day I reported this in one of my other threads: http://zero88.com/forum/topic/7331-confused-by-playback-overlaying/?p=28801 Separately, another Next issue: Playback 0 is on cue 6, Current:6 Next:7. Programming some other playbacks now, I'm seeing that the Next yellow bar on Playback 0 is jumping back to cue 1 after hitting one of the MFFs after RECORD (used syntax to set some levels, hit RECORD, hit eg MFF11). Also in the status row, Next:1. Also as an aside, I now press down arrow and the yellow bar jumps to cue 8 and Next:8. The Next cue really had changed, because if I GO on Playback 0 then the stack goes to cue 1 not cue 7 as it should have. This behaviour wouldn't appear to be intentional, and is a potential pain when building a cue stack if it is! Quote
Jon Hole Posted December 17, 2015 Report Posted December 17, 2015 Hi Kevin, Thanks - you're finding them all at the moment! We really appreciate it :-) Added as ZOS-6856 Quote Jon Hole linkedin.com/in/jonhole
