Sven76 Posted December 15, 2015 Report Share Posted December 15, 2015 Hi everybody, I'd like to ask you some questions about how to work with playback- faders on an ORB XF: How can I assign a specific cue stack to a playback fader of my choice (of course only on of the button 20) For example if I want to have cue stack 201 on fader 1 and cue stack 43 on fader 2 (and so on). Or is it only possible to have cue stacks 1-20 on those faders? 2nd question: How can I delete/ unassign a stack from a fader again 3rd Question: How can I "Stop" a cue stack of a specific fader (I mean really "stop" and not just pause. BTW: how do I pause a stack on a fader 😀) 4th Question: Can those faders have different functions (like cross fade between cues) or is it only possible to have them as master fader for the stack? I guess so far that's it for the start 😉 Thank you in advance for your answers. Best regards Sven Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted December 15, 2015 Report Share Posted December 15, 2015 Hi Sven, Hopefully this will help! How can I assign a specific cue stack to a playback fader of my choice (of course only on of the button 20)For example if I want to have cue stack 201 on fader 1 and cue stack 43 on fader 2 (and so on).Or is it only possible to have cue stacks 1-20 on those faders? The bottom 20 faders ("playbacks") can be Cue Stacks 1 - 20, 21 - 40, 41 - 60 etc, using the syntax STACK PAGE x ENTER, where x is the page number. (On ORB XF, the "stack" button actually says "select stack"). You can also use syntax like STACK x MOVE TO STACK y ENTER to move stacks around. 2nd question: How can I delete/ unassign a stack from a fader again Hopefully the above tells you this - you could change to a different page, or move the stack somewhere else. To delete a stack, use the syntax "STACK x DELETE" or "DELETE STACK x ENTER", but this will permanently delete all the cues within that stack. 3rd Question: How can I "Stop" a cue stack of a specific fader (I mean really "stop" and not just pause. We call this "releasing". Hold down the RELEASE button, and press the flash button of the playback. BTW: how do I pause a stack on a fader Currently, you can only pause on the Master Cue Stack on ORB XF 4th Question: Can those faders have different functions (like cross fade between cues) or is it only possible to have them as master fader for the stack? Yes, hold SETUP and press the flash button, and then change the "Intensity Mixing" option in the window that opens. I'd advice releasing the stack (as above) after you change these settings. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Sven76 Posted December 16, 2015 Author Report Share Posted December 16, 2015 Hi Jon, al usual: That helped perfectly 😊 Tested all today and everything worked as you described. Thak you and best regards Sven Quote Link to comment Share on other sites More sharing options...
