pweijden Posted December 9, 2015 Report Posted December 9, 2015 Hi All, could someone help me with the fixture profile for the Beamz MHL-74 12 channels? The manual can be found here: http://www.wlshop.nl/files/content/files/150_518_Manual_vI.pdf Many thanks, Paul Quote
JB97 Posted December 9, 2015 Report Posted December 9, 2015 I'll give it a go now, but I might have to defer as I'm not amazingly confident xD Edit - I couldn't see how to best do the split for 8/13 channel mode... Or how to do pan and tilt fine.. Sorry :/ Quote
kgallen Posted December 9, 2015 Report Posted December 9, 2015 Try this one. No detail in the manual for the sub-channel detail, so you'll have to suck-it-and-see! Note - no 12 channel mode; manual provided has 8 and 13 channel modes... Kevin Edit - I couldn't see how to best do the split for 8/13 channel mode... Two separate fixture definitions within the one manufacturer, one for 8ch one for 13ch. I usually create the larger one, then chop down for the smaller. Or how to do pan and tilt fine.. Sorry :/ Make Pan and Tilt 16-bit ( Size=Word {16-bit} ), then set the Channel (LSB) for the Fine, and the Channel (MSB) is then the Coarse. beamz_mini_wash_7x10w.ift Quote
