I'll give it a go now, but I might have to defer as I'm not amazingly confident xD
Edit - I couldn't see how to best do the split for 8/13 channel mode... Or how to do pan and tilt fine.. Sorry :/
Try this one.
No detail in the manual for the sub-channel detail, so you'll have to suck-it-and-see!
Note - no 12 channel mode; manual provided has 8 and 13 channel modes...
Kevin
Two separate fixture definitions within the one manufacturer, one for 8ch one for 13ch. I usually create the larger one, then chop down for the smaller.
Make Pan and Tilt 16-bit ( Size=Word {16-bit} ), then set the Channel (LSB) for the Fine, and the Channel (MSB) is then the Coarse.
beamz_mini_wash_7x10w.ift
