LEDJ Intense 9HEX10 Fixture
kgallen
Hi Jon,
I wrote a set of fixture profiles for the LEDJ Intense 9HEX10 (9 channel mode options).
I referred to the LEDJ Intense 9P10 you tuned for me a while back, and hopefully I've constructed this one to your guidelines. One question/deviation, for the strobe channel, I set the Special type to Strobe rather than None as in your 9P10. Not sure if I did the right thing there.
Manual is here: http://www.prolight.co.uk/images//media/LEDJ254A/LEDJ254A-um0.pdf?ProlightConcepts=ylrlcnhjmgfn
Please tune if required and add to the next fixture library release.
Thanks,
Kevin
ps Sorry if it's more hassle to check someone else's fixture file than creating it yourself from scratch from the manual!
LEDJ_Intense_9HEX10.ift
Hi Kevin,
Thank you for making the profile and sending it over. I've quickly glanced over it and it all looks good, so we'll add it to our next library release.
Either is fine, but setting it to strobe definitely makes sense. The "special" option is used for two things:
First, the "special" option links parameters to specific functions within ZerOS - such as a the Colour Picker and the Pan / Tilt grid. There aren't any "special functions" for strobe, so this is irrelevant in this situation.
Secondly, the "special" option is used when swapping out a fixture for another type of fixture (using the "change" button in SETUP > Edit Fixtures > Patch) to match parameters between the two fixtures.
All the best,
Jon
Jon Hole
