soakes94 Posted November 10, 2015 Report Share Posted November 10, 2015 I was wondering if anyone has controlled the FLX with MIDI? I'm planning to cue the desk using Q-Lab and just wondering if anyone has done this before and if so what USB > MIDI controller did you use? I don't have a controller yet so would need to buy one but want to make sure I buy one that works, had bad experience with cheap MIDI controllers that just don't seem to do the job. Cheers Stephen Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted November 10, 2015 Report Share Posted November 10, 2015 I don't have a controller yet so would need to buy one but want to make sure I buy one that works, had bad experience with cheap MIDI controllers that just don't seem to do the job. Yes, this link might give you a little more info about that: http://www.arvydas.co.uk/2013/07/cheap-usb-midi-cable-some-self-assembly-may-be-required/ It shouldn't matter which midi units you use, but as the above explains, the really cheap ones cut corners and fail to keep to spec. We've got MOTU units which work well and aren't too expensive. A lot of USB / FireWire sound cards also have MIDI outputs on them, so worth looking at those. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
soakes94 Posted November 10, 2015 Author Report Share Posted November 10, 2015 I had tried one just like that one in the link and it didn't work! Thanks for advice I will maybe pick up a USB sound card with MIDI. 2 birds with 1 stone! Cheers Stephen Quote Link to comment Share on other sites More sharing options...
