Wiesmann Posted November 6, 2015 Report Posted November 6, 2015 Hello, I got a Problem with a Chilli 1210i. It works at the manual-mode but not via DMX. "NO DATA" is always displayed. The DMX-signal is correct (measuring device and different controllers direct connected to the input). Reset without success. Caused by an input-driver? Thanks a lot. Quote
KWR88 Posted November 6, 2015 Report Posted November 6, 2015 From the information that you have given it sound like DMX receiver has failed. these are surface mount parts so would need to looked at to replace them. if you PM on the address below with your location I can point you at your closest service agent. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
