Batmink Posted September 23, 2015 Report Posted September 23, 2015 Hi, I am looking for a profile for the Visage Eco LED Par VIS0484.1. I have attached the manual. Can you make one for the 6 + 10 channel modes. Regards Jon VIS0484.1 Manual EcoMultipar Par 6in1.pdf Quote
Jon Hole Posted September 23, 2015 Report Posted September 23, 2015 Hi Jon, Here's the profile for you, in both modes. Visage VIS0484 1.ift All the best, Quote Jon Hole Global Product Manager, Systems and Control
luke1307 Posted October 10, 2015 Report Posted October 10, 2015 Hi Jon Sorry if this post twice, my internet crashed as I was uploading comment so unsure if it uploaded. Thanks for making the visage VIS0484.1 fixture however you can not turn the UV setting on via the console which should be channel 10, please may you update this Quote
Jon Hole Posted October 12, 2015 Report Posted October 12, 2015 Hi, I've merged the two topics together to keep it all in once place. I've looked through the manual and the profile we created and it should be working correctly, there's nothing wrong that I can see there. Jon Quote Jon Hole Global Product Manager, Systems and Control
luke1307 Posted October 12, 2015 Report Posted October 12, 2015 Ok thanks, il try re adding the profile and try again Quote
luke1307 Posted October 12, 2015 Report Posted October 12, 2015 Hi Jon, I have re-loaded the profile, and been through the pallets, picker, faders and even effects and can not get the UV to come on, there doesn't even seem to be a pallet or fader for UV. Any ideas? Quote
keredyelesob Posted October 12, 2015 Report Posted October 12, 2015 Colour pallets are made up of the red, green, blue elements so you wont see the uv there. You should however see it above the encoder wheels when in the colour parameters. If you dont see uv listed try pressing the colour button again (this will show more colour parameters) Apologies if you have already tried this just thought it may be why you cant see the uv parameter. Quote
NickTaylor Posted April 10, 2017 Report Posted April 10, 2017 Downloaded the profile and works fine on my Frog 2. Thanks Keith as always. As to the UV issue its on the same bank as the Amber and white, ie the second bank of colour controls Quote
