Prayer Posted October 8, 2015 Report Posted October 8, 2015 Hi. When i do load for editing submasters or memory in LTP mode all working properly. But when i want edit submasters or memory on HTP mode, I have problem because load working but i can not change level presets those who is programed on loaded submaster or memory. Blind mode on mode HTP not working like on LTP. But it not so important for me. Solution xl ZerOs 7.8.2. What am doing wrong? And another question: when loaded submaster or memory, into the program window for editing, can select preset number with mouse cursor or buttons "left" "right" "up" "down". Or it is difficult to do, if would possible to change percent of presets with plus (+) and minus (-) buttons ? Sorry for my English. Thank you for your attention. Quote
keredyelesob Posted November 23, 2015 Report Posted November 23, 2015 Hi. When i do load for editing submasters or memory in LTP mode all working properly. But when i want edit submasters or memory on HTP mode, I have problem because load working but i can not change level presets those who is programed on loaded submaster or memory. Blind mode on mode HTP not working like on LTP. But it not so important for me. Solution xl ZerOs 7.8.2. What am doing wrong? I also get this problem when in HTP but is does make sense. If the memory you have loaded is higher than the value you want to go to then the HTP rule says that the memory should win. I normally use my desk in LTP but can see your problem when working in HTP. I think maybe if Zero88 implemented your suggestion of allowing direct editing of the programmer window this may make things a little easier for users working with the HTP desk behavior. Quote
