Hi all.
I am new to Zero88 consoles and just having a little problem with my FLX, I am due to programme a show so an untrained person can operate the console using purely the master playback go button, it will let me record to the fader but when I press the go button nothing happens, I have tried the playback settings but nothing seems to work, any help would be appreciated.
Thanks
Luke
Hi Luke,
Make sure the programmer is empty - you do this by pressing "CLEAR" twice. The programmer "always wins", and so if there's a load of "0%" under all the channels (which will be shown in red) then this might be the cause. This often happens when programming from channel faders, as once you're finished recording you pull all the channels to 0% - putting lots of "0%" info into the programmer which need to be cleared before playback.
Jon
Jon Hole
