I have recently bought the Jester ML and upgraded the firmware to 4.1, however, the LCD 3 screen is not displaying anything, and only has the backlight on.
I feel sure is was working before the upgrade?
I have tried adjusting the contrast etc but no luck.
Does anyone have a suggestion how to fix it, or does it need to go off for repair and if so how much will it cost?
This sounds like a hardware issue in that case. We can try two software things first:
- Try resetting the console completely
- Try installing old software to see if this solves the problem (I highly doubt it will, but please let me know which version you were using previously and I'll send it across)
Hi David,
As Jon has said it is looking like a hardware fault. Would need to see the desk to be able to confirm 100%.
PM on the address below to discuss the options we have on this.
Keith Rogers
