jw-lighting Posted September 6, 2015 Report Posted September 6, 2015 Hi, often i want to use Next an Prev to select fixtures. But i cant find out when the arrow keys left and right acts as Next and Prev. Most times, im only navigating in the table cells of the playback window or somewhere else. Is there a way to consequently use them as Next an Prev? Can i configure UDKs with Next and Prev? If not, may you implement something like this in the next version? Regards, Jan Quote
Jon Hole Posted September 10, 2015 Report Posted September 10, 2015 Hi Jan, In the next software release, Next / Previous will work solidly when "Highlight" is enabled. Only when Highlight's enabled will Next / Previous be supported. All the best, Jon Quote Jon Hole linkedin.com/in/jonhole
jw-lighting Posted September 13, 2015 Author Report Posted September 13, 2015 Hi Jon, i remember Next and Previous worked in every situation with a older version? (Or was it the ORB??) I really liked to use it to select colours or positions for a group of lights. Maybe you could make Next and Previous available in all situations by pressing Shift and Arrow Keys together? A other cool feature would be the following: 1 and 2 and 5 and 10 Enter : Selects 1, 2, 5, 10 Next : Selects 1 Next : Selects 2 Next : Selects 5 Next : Selects 10 Next : Selects 1 Prev : Selects 10 Clear : Clears selection 11 Enter : Selects 11 Next : Select 12 ... So you're moving in the selected group of lights until the next clear. Just as an idea - would be a great time-saver in my opinion! Quote
