Hi there,
I have a problem with updating the fixture library in my Jester ML48. I've created a new fixture - an itf file - in Fixture Editor. Now I'm trying to load it into the desk - I've put that on my USB stick, put the stick into a slot on Jester, went into setup, hit Update Fixture Library, and after hitting OK it says for a second Updating 0% Progress and just after that - Wrong File type. What I've done wrong ?
Or add my devices to the library , please, very necessary , urgently
1. PR LIGHTING LED SPOT 400 PR-8150
2. SILVER STAR MX-INDIGO 5000_YG-LED623
3. SILVER STAR SOLAR2 / ETZ
4. SILVER STAR YG-LED322TXW BOXER/TZ
thank you very much
Hi SDGLight,
you tried to overwrite the origin "factory Lib" with your user Lib which is not possible.
To assign your fixtures to your desk pls follow further steps.
connect your usb stick with your user fixture lib.
activate setup mode and go to assign fixtures.
choose "add fixture".
1.Now you will see a few options displayed in the upper MFK display. choose USB stick.
the desk reads your usb stick.
2. Select your user fixture Lib.
3. Next you need to select manufacturer by pushing mfk of start letter.
4. select fixture type
5. assign MDK fixture Button.
6. repeat upper steps till all your fixtures are assigned.
7. exit "assign fixture"
8. patch you fixures.
cheers
Sven
Sven Paulsen
Klangfarbe Vienna
