Enchancher Posted July 21, 2015 Report Posted July 21, 2015 Is there a possibility to run lightshows with a Timecode synchronized with a Song over Midi for example? Thanks Enchancher Quote
Jon Hole Posted July 21, 2015 Report Posted July 21, 2015 Hi Enchancher, We don't support MIDI Timecode on the Jester. We do, however, support MIDI Show Control. If you are using something like QLab, you can program it to send MIDI Show Control commands at specific points when you start playing a track. Hope this helps Jon Quote Jon Hole linkedin.com/in/jonhole
Enchancher Posted July 21, 2015 Author Report Posted July 21, 2015 But is there an update in work? So that you can synchronize your song exactly with your lights. Because if something like this is possible the Jester Ml24 is perfect. Thanks Enchancher Are there in general updates planned with some "big" changes like tools added for the ml series? Quote
Jon Hole Posted July 21, 2015 Report Posted July 21, 2015 Hi Enchancher, We release stability updates as-and-when we need to (very rare), but apart from that there are no software updates currently scheduled for the Jester range of consoles. Regards Jon Quote Jon Hole linkedin.com/in/jonhole
