Hi since version v7.8.3.2 you have made the intensity available (through the setup) on the first encoder wheel, i really like this,
I have however noticed that the fourth encoder wheel does not get assigned parameters very often, in past releases i thought it was just the way my custom fixtures where setup but now i am unsure.
The problem
if I set the intensity to always show on the first encoder,
select a fixture
Select effects pallets
select an effect
the encoders show [intensity, speed,size and nothing].
If i press the effects button again (used to show more parameters) then the fourth encoder shows offset.
This also happens with position,
default i get [intensity,pan,tilt, nothing]
pressing the position button a second time i get [intensity ,pan,tilt,motor speed].
The following problem may be my custom fixtures.
If i don't have the intensity set to always show.
I have a custom red,green,blue,white LED fixture,
if i select colour i only see [Red,Green, Blue nothing] across the encoders.
if i select colour again i get [white, nothing nothing,nothing] across the encoders.
is it possible for all four of the encoders to populate without making an new fixture?
I have the same problem with beam shape and position.
