gmanno Posted July 16, 2015 Report Posted July 16, 2015 Hello All I am trouble with the eurolite rgba bar 2 fixtures, could you please create them for me? the 6 channels version is this: ch1 0-255 red ch2 0-255 green ch3 0-255 blue ch4 0-255 amber ch5 0-255 master dimmer ch6 0 on - 1-5 sound control - 6-10 on - 11-55 flash I am very interested to the 19 channels fixture which i have attached description. will very appreciate your help all the best :) Quote
Jon Hole Posted July 16, 2015 Report Posted July 16, 2015 Hi gmanno, Here's the 6 channel fixture you requested. RGBA Bar 2 6ch.ift There was not attachment of the 19 channel fixture? All the best Jon Quote Jon Hole linkedin.com/in/jonhole
gmanno Posted July 16, 2015 Author Report Posted July 16, 2015 Hi Jon, thanks for your quick replay, I have attached another file, could you try to open this? many many thanks gmanno hello again, I cant find your file for the 6 ch version,...could you attach it again ? cheers gmanno pdf euroligts.pdf Quote
Jon Hole Posted July 16, 2015 Report Posted July 16, 2015 Hi gmanno, Sorry - reattached the 6ch profile to the post above. For the 19 channel mode, we suggest patching this as four separate fixtures (one for each "cell" of the bar), which will make it easier for you to program (so long as your console can support the increased number of fixtures). I've attached a personality, with the first 7 channels (mode, dimmer, strobe and the first cell of R,G,B,A). For the other three cells, use the "RGBA" profile that's within "Standard Fixtures" > "Conventionals". So, if the bar is addressed to DMX 50, you'd patch the following on the console: Cell 1 - Address 50 - RGBA Bar 2 (profile attached below - 7 channels) Cell 2 - Address 57 - RGBA (Standard Fixtures > Conventionals - 4 channels) Cell 3 - Address 61 - RGBA (Standard Fixtures > Conventionals - 4 channels) Cell 4 - Address 65 - RGBA (Standard Fixtures > Conventionals - 4 channels) Hope this makes sense? RGBA Bar 2 19ch (first 7ch only).ift Quote Jon Hole linkedin.com/in/jonhole
